Hello Guest it is November 24, 2026, 09:09:01 PM
Author Topic: Button Script works in debug mode but not when clicked - 4612  (Read 13967 times)
This is code that has worked prior to updating to 4612.  This homes my C axis (rotary) in the left up script.  When I step through the code in debugger it homes but when clicked no homing takes place.  Last message is output, 'Homing: 0.0'.
Any Ideas?
Code: [Select]
local function myHomeC()
  local inst=mc.mcGetInstance()
  local sState
  local pos=-1
mc.mcCntlEnable(inst,0)
mc.mcCntlConfigStart(inst)
  local hSigH=mc.mcSignalGetHandle(inst,mc.ISIG_MOTOR3_HOME)
  rc=mc.mcSignalEnable(hSigH,1)
  mc.mcProfileWriteInt(inst,'Signal68','Enabled',1)
  mc.mcProfileSave(inst)
  mc.mcProfileFlush(inst)
mc.mcCntlConfigStop(inst)
mc.mcCntlEnable(inst,1)
  local hSig,rc=mc.mcSignalGetHandle(inst,mc.ISIG_INDEX)
  if rc==mc.MERROR_SIGNAL_NOT_FOUND  then
    wx.wxMessageBox('wrong Signal')
  end
  sState=mc.mcSignalGetState(hSig)
  if sState==1 then  -- sitting on the slot so move off it
    mc.mcCntlGcodeExecuteWait(inst,'g0 f20000 h15\n')--g1 h366 f5000')
  end
  rc=mc.mcAxisHome(inst,mc.C_AXIS)
--this never gets executed
 mc.mcCntlSetLastError(inst,'Homing')
  repeat
    wx.wxMilliSleep(1000)
    rc= mc.mcAxisIsHoming(inst,mc.C_AXIS)
    mc.mcCntlSetLastError(inst,'Homing: '..tostring(rc))
  until rc==0
  rc=mc.mcSignalEnable(hSigH,0)
end
  myHomeC()
end
TIA
RT
GOOMBA
Re: Button Script works in debug mode but not when clicked - 4612
« Reply #1 on: March 22, 2021, 12:37:28 PM »
RH,
Is the whole purpose of this script just to home the C axis?
Do you want it inside an M code?
I see a lot of stuff in there that may not be necessary like profile saves and flushes the enable signals etc.
Can you just give me a little description of use case and I may be able to help :)
« Reply #2 on: March 22, 2021, 01:06:13 PM »
Yes it is to Home the C axis.  My spindle has a timing gear that I have a belt for one motor to spin and another belt to change out and have it powered by a stepper so as to act as an indexer.  The other profile code was to try and disable the motor so it would stop sending Home C switch activated signals when not in use as a C axis.  The Home signal shares the slotted disc on the spindle for speed recognition.
The problem is that this worked for over a year with a couple of different builds but now with 4612 it does not.  I reverted to an earlier build and it works again. I submitted a ticket with my profile packaged Saturday.
Thanks for taking a look at this.
RT
Offline smurph
  •  1,575 1,575
« Reply #3 on: March 22, 2021, 02:36:47 PM »
Is this a M code macro script?  Or does something else call the myHomeC() function?
If you have this code in M code, say m200.mcs, it will never get called.  Because there is no function stub called m200().
Steve
« Reply #4 on: March 22, 2021, 02:40:54 PM »
As I said in my initial.post this is in a left up button script
Offline smurph
  •  1,575 1,575
« Reply #5 on: March 22, 2021, 02:47:58 PM »
I was trying to find out where this script resides.  I assume that if some button script must call it that it is in your screen load script?  Or is that ALL in the left up script?
Also
goes where/does what?  You are waiting on G code that never moves.  Did you mean to move the C axis off the switch?  Maybe "G91 G0 C1"
Steve
Offline smurph
  •  1,575 1,575
« Reply #6 on: March 22, 2021, 02:50:40 PM »
If it is ALL in the left up script, what calls myHomeC()?  I see a function stub a the bottom of the script:
  myHomeC()
end
But that will ONLY call the myHomeC() function IF you are inside the code editor.  That is a M code macro script style function stub.  It isn't needed in a button script.
Steve
Offline smurph
  •  1,575 1,575
« Reply #7 on: March 22, 2021, 03:10:02 PM »
Put this in your screen load script.  Notice I removed the local keyword from the function definition.  This way, you could have multiple buttons call this function, if you wish.
Code: [Select]
function myHomeC()
local inst=mc.mcGetInstance('myHomeC()') -- this will log all API calls as coming from source "myHomeC()"
local sState
local pos=-1
rc = mc.mcSignalEnable(hSigH,1)
mc.mcProfileWriteInt(inst, 'Signal68', 'Enabled', 1)
local hSig,rc=mc.mcSignalGetHandle(inst, mc.ISIG_INDEX)
if (rc == mc.MERROR_SIGNAL_NOT_FOUND) then
end
sState = mc.mcSignalGetState(hSig)
if (sState == 1) then  -- sitting on the slot so move off it
mc.mcCntlGcodeExecuteWait(inst, 'g0 f20000 h15\n')--g1 h366 f5000')
end
rc = mc.mcAxisHome(inst, mc.C_AXIS)
mc.mcCntlSetLastError(inst, 'Homing')
repeat
rc = mc.mcAxisIsHoming(inst, mc.C_AXIS)
until rc == mc.MERROR_NOERROR
rc = mc.mcSignalEnable(hSigH, 0)
end
And then simply put:
myHomeC()
in any button's left up script you want.
I know I harp on error checking, but...  it needs more error checking!  :)
I also still don't like the G code execute wait that doesn't move.  It may or may not cause problems.
« Reply #8 on: March 22, 2021, 03:29:29 PM »
Steve, thank you for taking time to look at this, it is much appreciated.
The G91 has no meaning in lathe mode, ergo the g0 h15 moves the spindle 15 degrees relative to where it is at which is enough to move it off of the optical slot.
I added the 'mcineditor' trying to find a way to get this to work, which it didn't, so originally just had the function definition and the call to it in the button script.  Took it out after my initial post.  I will try adding your example to the screen load script when I get some free time and am ready to go back to 6412.
RT
Offline smurph
  •  1,575 1,575
« Reply #9 on: March 22, 2021, 03:34:17 PM »
Ahh...  lathe.  :)
This is what I mean by error checking.  It is verbose and wordy with lots of IF statements.  But with good error checking, there will be no mysteries if something goes wrong.  It will help you 1, 2 or 3 years from now when you are troubleshooting something when a rodent eats through a switch wire, etc...  LOL
Ideally, you should check the return code of every API call that is critical to the success of the script at hand.
Code: [Select]
function myHomeC()
local sState
local pos = -1
local hSig
local hSigH
local rc
rc = mc.mcCntlEnable(inst,0)
if (rc ~= mc.MERROR_NOERROR) then
wx.wxMessageBox('myHomeC(): Could not disable the machine.')
return
end
rc = mc.mcCntlConfigStart(inst)
wx.wxMessageBox('myHomeC(): Could not command the configuration state.')
return
end
hSigH, rc = mc.mcSignalGetHandle(inst,mc.ISIG_MOTOR3_HOME)
wx.wxMessageBox('myHomeC(): Could not get the motor 3 home signal handle.')
return
end
rc = mc.mcSignalEnable(hSigH, 1)
wx.wxMessageBox('myHomeC(): Could not enable the motor 3 home signal.')
return
end
rc = mc.mcProfileWriteInt(inst, 'Signal68', 'Enabled', 1)
wx.wxMessageBox('myHomeC(): Write the motor 3 home signal state to the profile.')
return
end
rc = mc.mcProfileSave(inst)  -- Do we really need to save the mach config to the profile?
wx.wxMessageBox('myHomeC(): Could not save the Mach config to the profile.')
return
end
rc = mc.mcProfileFlush(inst)
wx.wxMessageBox('myHomeC(): Could not flush the profile to disk.')
return
end
rc = mc.mcCntlConfigStop(inst)
wx.wxMessageBox('myHomeC(): Could not exit the config state.')
return
end
rc = mc.mcCntlEnable(inst,1)
wx.wxMessageBox('myHomeC(): Could not enable the machine.')
return
end
hSig, rc = mc.mcSignalGetHandle(inst, mc.ISIG_INDEX)
wx.wxMessageBox('myHomeC(): Wrong Signal')
return
end
sState, rc = mc.mcSignalGetState(hSig)
wx.wxMessageBox('myHomeC(): Error getting signal state');
return
end
rc = mc.mcCntlGcodeExecuteWait(inst, 'g0 f20000 h15\n')--g1 h366 f5000')
wx.wxMessageBox('myHomeC(): Error executing G code.  rc = ' .. tostring(rc) .. ".");
return
end
end
wx.wxMessageBox('myHomeC(): Error homing the C axis.');
return
end
repeat
wx.wxMessageBox('myHomeC(): Error getting the C axis home state.');
return
end
wx.wxMessageBox('myHomeC(): Could not disable the motor 3 home signal.')
return
end
wx.wxMessageBox('myHomeC(): Could not flush the profile to disk after home C is complete.')
return
end
end
Steve
