Hello Guest it is November 13, 2026, 09:59:06 AM
Author Topic: Router won't respond to mach3  (Read 8308 times)
« on: March 18, 2021, 05:08:48 PM »
Hi everyone. Need some help. My mach 3 program won’t communicate with my Router? About a year ago I converted a  mill to cnc and control it with  mach 3. When I was setting up my mach program for the mill, I would refer to settings for my cnc wood router, some times. After getting my mill running I haven’t used my wood router since, until a couple days ago. Well, now I can’t get my router to jog. When I plug in my usb cable, the light shines on the breakout board. Drivers all have green lights. Everything looks good, I think? I always run with the cover on, so I really don’t know. I am wondering if I didn’t change something by accident when I was peeking, setting up my other mach profile? I don’t see anything wrong with my settings, but I admit, I’m not very sharp
thanks
Rick
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Router won't respond to mach3
« Reply #1 on: March 19, 2021, 07:32:01 PM »
If you look in the Mach3 folder you will find some backup XML files copy the current one out and replace it with a file with a much older date stamp and see if that works.
