Hello Guest it is November 11, 2026, 09:33:43 PM
Author Topic: network setup, and how to run G100.m3p file  (Read 17787 times)
« on: October 11, 2007, 04:37:59 PM »
setting up a g100 under mach 3....
in setting up the network, I assigned 192.168.1.100 to the pc.
when I ping 192.168.1.10 , I get the message request timed out.
the setup guide  indicates this to be a cabling problem, but I am using a brand new network crossover cable bought from staples, connects the pc directly to the g100.
comments?
also, when I try to run G100.m3p, winxp asks me what to open it with.
Huh? the setup guide makes no reference to this.
Re: network setup, and how to run G100.m3p file
« Reply #1 on: October 11, 2007, 05:07:33 PM »
Did you place the G100m3p folder in your Mach folder and double click it? What version of Mach are you runnig?
« Reply #2 on: October 12, 2007, 08:22:20 AM »
I'm Currently using 1.84.001
I put the the file g100.m3p in the mach3 folder
when I double click it, windows asks me what to open it with.
« Reply #3 on: October 12, 2007, 08:52:45 AM »
Download the latest version of Mach please. Also, make sure you have Mach installed on your C drive.
« Last Edit: October 12, 2007, 08:54:16 AM by Chaoticone »
« Reply #4 on: October 20, 2007, 01:14:23 PM »
comments?
same problem found with 2nd pc, but same cable.
wondows recognizes a network connection, but when I ping 192.168.1.10, I get the message "request timed out"
again, the setup guide indicates a cabling problem.
any other suggestions?
« Reply #5 on: October 20, 2007, 04:06:41 PM »
I have made progress here...
Now I seem to have everything up to snuff, except, when I start mach3, the g100 is recognized for a few seconds, then I get the message communication lost.
