Hello Guest it is November 23, 2026, 08:11:12 PM
Author Topic: How to Sett Tool #1 on Startup in Mach3  (Read 8494 times)
« on: March 11, 2021, 05:11:24 AM »
I have a router with two spindles as the easiest way to implement a simple tool changer.  It runs Mach3 with negative tool lengths.
Mach3 starts with the tool # set to 0 which has length 0 which is always wrong.  If I forget to set Tool 1 before I set my work zero position then as soon as the G Code sets Tool 1, my work zero is now below the bed of the machine with undesirable consequences!
As a way round this, I thought I would set the tool # to be 1 in RefAllHome using SetCurrentTool(1).  This works as Tool 1 details are shown on the Program Run screen, but Mach3 does not seem to pick up the tool length at this point so I still have the same problem.  If I do a manual G43T1, (pick up the tool length for this tool from the tool table) all is happy, so how do I do the equivalent of G43H1 from within RefAllHome?  Neither Code "G43H1" nor Code("G43H1") do anything at all.
Is there a better way to solve my problem please?  If not, how do I get Mach3 to recognise the length of Tool1 from the tool table having selected it it RefAllHome?
Many thanks, Nick
Offline TPS
  •  2,627 2,627
Re: How to Sett Tool #1 on Startup in Mach3
« Reply #1 on: March 11, 2021, 05:21:30 AM »
a:
Code: [Select]
  SetOEMDro(824,1)
should set everything.
can also set in Config -> General Config -> ToolDro persistent
« Reply #2 on: March 12, 2021, 08:22:09 AM »
I have used the "  SetOEMDro(824,1)" and it works!  Huge thank you, that has been painful but only broke one cutter!
