Hello Guest it is October 05, 2026, 03:25:58 PM
Author Topic: Matrix LED and LCD not working in MACH3 plugin  (Read 26910 times)
« on: February 22, 2021, 12:28:46 AM »
I bought a very nice Siemens pendant that had been gutted and fitted with a Pokeys55 interface. All input are working as they should (analog, matrix keyboard, MPG, digital input). But both the LCD and matrix-LED fail to work from the plugin, however from the Pokeys configuration software they work fine. Sometimes I can see flicker on the matrix-LEDs and if I have set the LCD to something then starting Mach3 it gets cleared. Any ideas on solving this?
The plugin used is the latest one from the poscope website, found some earlier ones online but they were not near the same in helping the configure, so before I go down the route of trying something older with macropumps and whatever I wanted to know if this issue could be solved. Also if there are any logs I could look into, or even better if the plugin source code was available.
I have found another post here with the same issue that did not get any replies so I am hoping for this one :)
