Hello Guest it is October 24, 2026, 05:13:45 PM
Author Topic: a axis not working for cv mode  (Read 6996 times)
« on: February 20, 2021, 10:50:02 PM »
I am having problems with the a axis not moving smoothly between coordinates. The following example code works fine:
g64
g93
g1
a1 y1 f600
a2 y2 f600
a3 y3 f600
a4 y4 f600
When I remove the y coordinates and try to run the following code, the a axis stops at every point:
g64
g93
g1
a1 f600
a2 f600
a3 f600
a4 f600
I apologize if this is a g code error, and therefore in the wrong forum, but I am assuming it is a problem with my Mach4 setup.
Any help would be really appreciated!
Re: a axis not working for cv mode
« Reply #1 on: February 23, 2021, 06:17:36 PM »
Correct the cv is not done for the a axis
That is considered a positional axis
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: February 24, 2021, 10:25:35 AM »
Thanks Brian! That makes sense.
So my solution has been to add some "creep" to another axis while a is moving. Kind of silly, but it works ok.
What would be much better would be if I could switch back and forth between using the a axis as a spindle and an axis. It seems like mach3 might have had that ability? I posted that question as a new topic: https://www.machsupport.com/forum/index.php?topic=44433.0
