Hello Guest it is October 25, 2026, 11:00:07 AM
Author Topic: Mach4 powered 3d printer  (Read 5569 times)
« on: February 14, 2021, 08:02:29 PM »
Building a large 3d printer using ethercat a/c servos. I want to use Mach4 to run it, need someone to help setup Mcode to run extruder. I will most likely run extruder/bed heaters manually. 3d printers are the only cnc equipment I use, all my machining is done on manual equipment.
Re: Mach4 powered 3d printer
« Reply #1 on: February 15, 2021, 08:20:03 AM »
We have done this all in the past and if you contact the support guys they can give it to you ... It was going to be in the release but it didn't made it because I was on them to get testing finished.
www.newfangledsolutions.com
www.machsupport.com
