Hello Guest it is October 24, 2026, 04:59:56 AM
Author Topic: Concept Validation: Dual Belt Spindle Setup  (Read 16444 times)
Re: Concept Validation: Dual Belt Spindle Setup
« Reply #10 on: February 17, 2021, 03:43:28 PM »
I'm confident I can get the auto shifter working in PMC based on RPM conditions. But tweaking the analog out signal for different belt ratios is way over my head haha!
« Reply #11 on: February 19, 2021, 10:43:50 AM »
You make it shift and I more than happy to help you with the analog side!
www.newfangledsolutions.com
www.machsupport.com
« Reply #12 on: February 19, 2021, 11:14:37 AM »
Will do, thank you Brian.
I've started building some of the mechanical components. I will reach out to you on this thread once I reach the stage where analog modification is needed!
« Reply #13 on: February 19, 2021, 12:28:21 PM »
Nice! Looking forward to it.
www.machsupport.com
« Reply #14 on: April 12, 2021, 09:48:26 AM »
Hi Brian, it's been a while, but I'm finally getting ready to start the programming side of things for my spindle.
Can you point me in the right direction on how to go about modifying the analog output calculation in Mach? I can't seem to find any code/scripts relating to analog output in my Mach4 directory.
-Adam.
