Hello
Guest
it is
October 24, 2026, 04:12:57 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
Concept Validation: Dual Belt Spindle Setup
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Concept Validation: Dual Belt Spindle Setup (Read 16440 times)
tkalxx
14
Re: Concept Validation: Dual Belt Spindle Setup
Reply #10 on:
February 17, 2021, 03:43:28 PM »
I'm confident I can get the auto shifter working in PMC based on RPM conditions. But tweaking the analog out signal for different belt ratios is way over my head haha!
Logged
Brian Barker
3,860
Reply #11 on:
February 19, 2021, 10:43:50 AM »
You make it shift and I more than happy to help you with the analog side!
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
tkalxx
14
Reply #12 on:
February 19, 2021, 11:14:37 AM »
Will do, thank you Brian.
I've started building some of the mechanical components. I will reach out to you on this thread once I reach the stage where analog modification is needed!
Logged
Brian Barker
3,860
Reply #13 on:
February 19, 2021, 12:28:21 PM »
Nice! Looking forward to it.
Logged
www.machsupport.com
tkalxx
14
Reply #14 on:
April 12, 2021, 09:48:26 AM »
Quote from: Brian Barker on February 19, 2021, 12:28:21 PM
Hi Brian, it's been a while, but I'm finally getting ready to start the programming side of things for my spindle.
Can you point me in the right direction on how to go about modifying the analog output calculation in Mach? I can't seem to find any code/scripts relating to analog output in my Mach4 directory.
-Adam.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
