Hello Guest it is October 25, 2026, 07:53:54 AM
Author Topic: service timer  (Read 9551 times)
service timer
« on: February 05, 2021, 05:53:53 AM »
what is the best way to make timing for auto service(like run electric oil pump)
for example each 100 working h (h can be when Enable) force lubrication 1 minutes
thanks
yaakov
Re: service timer
« Reply #1 on: February 05, 2021, 07:29:41 AM »
2 ways that are easy... You can do an on screen timer in screen edit mode OR you can make a PMC file. https://www.youtube.com/watch?v=jVhH9qyjjf0
www.newfangledsolutions.com
www.machsupport.com
Re: service timer
« Reply #2 on: February 05, 2021, 08:06:17 AM »
please give me sample how do it with screen timer
,i didnt find any manual and i rea understand when you mean screen timer
Offline Bill_O
  •  615 615
Re: service timer
« Reply #3 on: February 05, 2021, 08:14:07 AM »
Here is what I use.
You need to make a couple of registers also.
In PLC
--  Cycle time label update
--Requires a static text box named "CycleTime" on the screen
if (machEnabled == 1) then
   local running = mc.mcCntlIsInCycle(inst)
   if (running == 1) then
      local cycletime = mc.mcCntlGetRunTime(inst, time)
      scr.SetProperty("CycleTime", "Label", SecondsToTime(cycletime))
      --run time
      local hRun = mc.mcRegGetHandle(inst, 'iRegs0/RunningTime')
      RunTime = cycletime
      mc.mcRegSetValue(hRun, RunTime)
   end
end
In PLC First Run section
   --Pop up message for maintenance
   --Keep at bottom
   local MaintReg = mc.mcRegGetHandle(inst, 'iRegs0/MaintTime')
   local MaintRegVal = mc.mcRegGetValue(MaintReg)
   if (MaintRegVal >= 144000) then
      mc.mcRegSetValue(MaintReg, 0.0)
      wx.wxMessageBox("Please perform maintenance")
   end
In the Cycle Start function in Screen Load Script
         --Set time on Maintenance timer
         local hMaint = mc.mcRegGetHandle(inst, 'iRegs0/MaintTime')
         local MaintTime = mc.mcRegGetValue(hMaint)
         local hRunning = mc.mcRegGetHandle(inst, 'iRegs0/RunningTime')
         local RunningTime = mc.mcRegGetValue(hRunning)
         MaintTime = (MaintTime + RunningTime)
         mc.mcRegSetValue(hMaint, MaintTime)
         mc.mcRegSetValue(hRunning, 0.0)
Re: service timer
« Reply #4 on: February 05, 2021, 08:22:19 AM »
At the top of the screen in screen edit mode you can mouse over the icons. The 2nd one from the right looks like a stopwatch. That is an on screen timer object. Place that on the screen and you can use that to call your code at your intervals you would like.
www.machsupport.com
Re: service timer
« Reply #5 on: February 05, 2021, 08:24:24 AM »
brian its not angular meter?
Re: service timer
« Reply #6 on: February 05, 2021, 09:57:38 AM »
It is in the newer versions I guess ..... I don't run old LOL
www.machsupport.com
Re: service timer
« Reply #7 on: February 06, 2021, 10:25:16 AM »
Where can download?
Offline smurph
  •  1,575 1,575
Re: service timer
« Reply #8 on: February 06, 2021, 12:14:09 PM »
http://www.machsupport.com/ftp/Mach4/DevlopmentVersions/
Get the latest one.  4609, I believe
Steve
