Hello Guest it is October 04, 2026, 09:01:20 PM
Author Topic: NOOB with a gcode question...?  (Read 23387 times)
« on: February 05, 2021, 12:05:28 AM »
So I am slowly wrapping my head 63 year-old head around Mach3 and gcode... but I have had something come up that I don't understand...
I was modeling a little plaque with some text to v-carve on my cnc router and get this gcode (it's 8000 lines- I won't paste the whole code!)
My questions are this: Line 14 is requesting tool #10- no problem. But when I re-choose "start" nothing happens... why?
So, I configured Mach3 to ignore tool changes, and it went past line N14, but hung up on N16... and there it's stuck.
So- why did it stick on N14, then why did it stick on N16?  Also, I chose "Mach3 ARCS inches" as my post processor- I didn't chose "Mach3 ATC" so why is it hanging at line N14 like its waiting for a tool change?
Is this a Vectric issue, or a Mach3 issue?
Help!!
Thanks for your time!
Oldcrowe
( V-Carve 1 )
( File created: Tuesday February 02 2021 - 08:50 PM)
( for Mach2/3 from Vectric )
( Material Size)
( X= 9.000, Y= 3.750, Z= 0.753)
(Toolpaths used in this file:)
(V-Carve 1)
(V-Carve 2)
(V-Carve 3)
(Tools used in this file: )
(10 = V-Bit {60.0° - 1/2"})
N120G00G20G17G90G40G49G80
N130G70G91.1
N140T10M06
N150 (V-Bit {60.0° - 1/2"})
N160G00G43Z0.8000H10
N170S12000M03
N180(Toolpath:- V-Carve 1)
N190()
N200G94
N210X0.0000Y0.0000F50.0
N220G00X1.3323Y3.4693Z0.2000
N230G1Z-0.0507F15.0
N240G1X1.3320Y3.4653Z-0.0506F50.0
N250G1X1.3317Y3.4495Z-0.0478
N260G1X1.3316Y3.4195Z-0.0394
Offline TPS
  •  2,627 2,627
Re: NOOB with a gcode question...?
« Reply #1 on: February 05, 2021, 12:41:25 AM »
if you are not working with toolchange and tool length compensation you can delete line N140 and N160 completly.
« Reply #2 on: February 05, 2021, 12:53:57 AM »
Great!  Thanks!  But... is there a simple explanation as to why they are even there?  Did Mach3 put them there, or did Vectric?
Offline TPS
  •  2,627 2,627
« Reply #3 on: February 05, 2021, 12:56:04 AM »
Vectric did.
N140 is the code to initiate toolchange
N160 is the code to activate tool length compensation
« Reply #4 on: February 05, 2021, 12:57:51 AM »
Thanks so much.  I'll check my Vectric settings to try to fix these...
Thanks again!
Offline ZASto
  •  434 434
« Reply #5 on: February 05, 2021, 04:39:19 AM »
You should choose a post processor which does not generate ATC code, from top of my head Mach2/3_arc_mm or Mach2/3_arc_inch (I'm not near the computer that I have Aspire on)
Make no mistake between my personality and my attitude.
My personality is who I am.
My attitude depends on who you are.
« Reply #6 on: February 05, 2021, 12:11:45 PM »
Thanks @ZASto-
But that brings up another quandary-
That code was generated by exactly what you mentioned-  "Mach3 arcs inches"  so I don't know how the tool change command got in there...
Offline ZASto
  •  434 434
« Reply #7 on: February 05, 2021, 12:47:41 PM »
Well, I guess that there are some lines in the post processor that should be removed.
put this modified post processor in your %programdata%/vectric/..../PostP (or My_PostP) folder.
I commented the offending/un necessary lines.
