Hello Guest it is October 25, 2026, 02:15:48 AM
Author Topic: cant load program more then 50M  (Read 13723 times)
« on: February 02, 2021, 02:07:27 AM »
when i try load programs more then 50m i got this messege:
"unexpected exeption has occured :bad allocation ,the program will terminate"
i look in mach i didnt see any limit of file size  ,shure not 50M its not so big
thks
Re: cant load program more then 50M
« Reply #1 on: February 02, 2021, 05:45:59 AM »
50 million lines is not that much ... I have made hundreds of thousands of parts and not needs a file that big. I have to know what takes a file that big?  If your going to need files that large you will need to make sure you have memory enough.  Please tell me a bit more so we can figure it out.
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: February 02, 2021, 05:54:47 AM »
not 50 million lines,3 million lines cant load,only if i disable the screen
i use dell i7 with EMD Radeon 610 screen adapter ,not gaimer  but sure not old style
when i mark"disable VBO tool path" its help little bit but also crash with program with 3 million lines
is there way to stay with the screen with large files?
« Reply #3 on: February 02, 2021, 05:55:57 AM »
50M file can load when mark thw disable vbo but 100M cant load any case only if i hide the screen
« Reply #4 on: February 02, 2021, 06:00:47 AM »
Have a look in the Mach4 directory at the displayfile.dat I think it is. How big is that file? The issue is one line requires much more data. We may need to kill the toolpath?
I am out moving snow taking a break :)  I will look when I get to my desk. I may need your file to test because I don’t have any files that big. I also don’t have any tools to make them that big :( .
www.machsupport.com
« Reply #5 on: February 02, 2021, 06:02:56 AM »
Sounds like OpenGL can’t do it :( we will see..
www.machsupport.com
« Reply #6 on: February 02, 2021, 06:10:01 AM »
send me yours mail ill send you by jumboMail
« Reply #7 on: February 02, 2021, 06:14:28 AM »
do you mean the"ToolDisplay0.dat"?
i dont see any diisplayfile.dat
« Reply #8 on: February 02, 2021, 07:09:41 AM »
Yeah that's the one.. Sorry I can't look at stuff like that on my phone :)
www.machsupport.com
« Reply #9 on: February 02, 2021, 07:10:52 AM »
its binary 220M file
