Hello Guest it is November 13, 2026, 11:30:04 AM
Author Topic: Problem with soft limits settings.  (Read 7556 times)
« on: January 29, 2021, 07:45:41 AM »
I am having trouble getting soft limits to work on my little Sherline conversion.
The machine homes to what I think are the correct locations ie: X trips the switch & backs off a bit with the table at the far left of its travel.  That is then X-zero with table movements toward the right going negative; max safe mechanical travel is -7.5".  Y trips & backs off at its farthest (away from the column) point.  Table movements toward the column are negative, max safe travel is -6.15".  Z zero is all the way up; traveling downwards is in the minus direction.
First, is this setup "normal' for a regular 3-axis column mill and second, would someone suggest a configuration for the Home & Limits page?  I think the "Home Off." setting is what is  giving me problems.
Thanks for any input.
Milton from Tennessee ya'll.
Offline TPS
  •  2,627 2,627
Re: Problem with soft limits settings.
« Reply #1 on: January 29, 2021, 10:49:52 AM »
Google for
three finger rule or right hand rule
than you can see what is "normal"
