Hello Guest it is November 13, 2026, 01:07:58 PM
Author Topic: [Help] One axis screen  (Read 63775 times)
« on: January 14, 2021, 05:57:37 AM »
Hi everyone, i'm trying to build something like this -->https://www.youtube.com/watch?v=dHXoMG2s5yE, but not so fancy xD
So, besides the doubts that i have with the hardware part of the project, i have a couple of problems with the software part of the project.
Basically I'm making my own screen since I didn't find anything that looks like what I need.
My first problem is that I don't know anything about programming, so for sure there are a lot of things that are basic but i am not aware, so sorry for that.
I will share a picture of what i have done, and some of my doubts
First of all i want to thanks to TPS for this fantastic keyboard https://www.machsupport.com/forum/index.php?topic=36213.msg247828#msg247828
Ok, better to start.
*The load and edit buttons are working perfectly
*The stop and home. I want to think that too [function stop (3); function Zero all (7)] i hope that I will be able to try it soon.
*The Go! button, i use the function set this line next to execute (156) but i don't see it in the target length [x dro (800)]
*I can't figure out how to choose between picking a length from the list or making a manual input. I saw the video and its look like he uses a led with some script, but as i said im realy lost there.
*On the Actual length [a machine cord dro (86)] its shows 0.00
But in the target length [x dro (800)] its shows -2.55 all the time and from the beginning, when i press in input target and the keyboard opens it shows too the -2.55, if i change the number and press ok, it doesn't change in the target length
I will realy apreciate a lot any kinde of help  :)
i will attach the .set file if someone want to look at it
Offline TPS
  •  2,627 2,627
Re: [Help] One axis screen
« Reply #1 on: January 14, 2021, 07:11:12 AM »
i assume you are referencing your machine to a limitswitch.
in this case the DRO Number for for Actual Pos is 83 not 86.
for the Manual Input you have to use a free DRO, not 800, because 800 is x-axis workcoord DRO.
the code for your Manual Input Button would then be something like this:
Code: [Select]
Sub Main
call NumericKeyboard(1400)
        Code "G0 X" &GetOEMDro(1400)
End Sub
#Expand <\..\..\macros\yourprofile\numerickeyboard>
make sure you use the correct path for #Expand intruction
to "work" through your loaded list i would set machine into single step  (DoOEMButton(1004)) and
then by each Cycle Start (DoOEMButton(1000)) it should exceute one line.
« Reply #2 on: January 14, 2021, 08:18:43 AM »
Thx again!
Ok, so i fixed the actual pos.
And i dont understand how to put a free dro :/
i changed the manual input and is working but only 1 time, i can put 1 time some number, press OK and then when i want to open again is not working :/
Offline TPS
  •  2,627 2,627
« Reply #3 on: January 14, 2021, 08:44:14 AM »
you have to Change the DRO Number of yourinput field to 1400
« Reply #4 on: January 19, 2021, 05:12:35 AM »
Thx again TPS!
So i make it work all the manual input thing (now i understand why you  put in the script the "&GetOEMDro(1400)")
I give up using your keypad because i couldn't make it work more than 1 time, so a friend told me that i can use the auto-calculator, it's a little small, but anyway)
Now i'm ashamed to say that i didn't understand a word about the list...
The g code is showing the txt, the load and edit buttons are working but the "GO!" its look like is not working, and i don't know if to add another dro to be able to see the cords of the list or if there is a way to show that in the target dro (that now is with the oem 1400)
I don't have a problem even to make two tabs, one for manual and another for list.
« Last Edit: January 19, 2021, 05:16:37 AM by aliorix »
Offline TPS
  •  2,627 2,627
« Reply #5 on: January 19, 2021, 06:49:48 AM »
made a quick and dirty wizzard
-create the Folder c:\Mach3\Addons\bladestop
-copy the attached file into this Folder
-restart Mach
-use load wizard
-select baldestop
-test
than you can look with screeneditor what i made in the entire buttons
« Reply #6 on: January 19, 2021, 07:06:05 AM »
Wow man, thank you for your time! really!
I tested.
Your keyboard still pop up 1 time, if i put any number and press ok, its working, but if i try to do it again it doesn't pop up
I see that in the GO button you put a condition (if) with a oemled, but i don't see any led's
So when i load the list, and press go i don't see anything happening. And if i scroll down in the list and chose anything, when i press go it come back to the first entry of the list.
Ah, and i see that you replace the actual length (oem 86) with a x oem
Offline TPS
  •  2,627 2,627
« Reply #7 on: January 19, 2021, 07:40:41 AM »
i made a simple g-code file for the list i loaded
Code: [Select]
X10
X20
X30
X40
-then i load this list with Load List button
-every time i press the GO button next line is excecuted
-with Reset List i rewind and go back to the begin of list
here everytime i press the Input Target button the simple Keyboard Shows up and after i press
Enter x-axis moves to the Position witch was entered.
i used OEMLed(82) with tells me that single step is turned ON, if not i turn it ON
(DoOEMButton(1004)).
OEMLeds are always updated even if they are not present at actual screen
Offline TPS
  •  2,627 2,627
« Reply #8 on: January 19, 2021, 07:45:49 AM »
if you enter the Manual Target press OK does Actual Length go to the given Position?
« Reply #9 on: January 19, 2021, 07:56:26 AM »
No, if I put some length in manual (or if I choose from the list) the actual doesn't change at all.
Maybe is a problem of my computer? i will try to test it in my house today and see if there is something different :/
Here i have win10  :(
