Hello Guest it is November 13, 2026, 12:32:10 PM
Author Topic: Changing from plasma to mill profile  (Read 21265 times)
Offline TPS
  •  2,627 2,627
Re: Changing from plasma to mill profile
« Reply #10 on: January 13, 2021, 11:05:27 AM »
you can use from main menu
View -> Load Screens
to load an other screenset
« Reply #11 on: January 18, 2021, 09:55:07 AM »
I did load the changed xml file for the mill profile and it works fine, that problem is solved.
Next problem to solve: the breakoutboard (STB4100) does not have any power on the connector for the spindle speed (00-10volt)
Offline TPS
  •  2,627 2,627
« Reply #13 on: January 18, 2021, 12:34:23 PM »
Thank you, that's the manual I used and checked the settings already 3 times, still no power on the 0-10 volt pin (DAC).
I ordered a new one, because I think that mine is not working and in order to have one to play around with in the office. It is quite cold in the workshop to seat and program and the machine is to big of the office...
The new one will hopefully arrive on Friday, so that I may test it over the weekend.
Currently I try to work out the frame to build on. Currently the prototype is build out of wood (left overs). So I will have to change that to aluminium and hopefully I may produce the needed parts already with my prototype.
« Reply #14 on: January 25, 2021, 06:18:16 AM »
Got the new board, and now it works partly, got power on the pin (0-10) and the inverter reacts accordingly.
Still the spindle does not react, so I guess this is a setup problem with the parameters of the inverter, still investing.
Does any one may tell me how to connect plasma to the board? It seems that a relais is needed to use the 5 volt signal to switch on the 220 volt switch for the torch.
Offline TPS
  •  2,627 2,627
« Reply #15 on: January 25, 2021, 08:36:21 AM »
normaly the torch ON button from the manaul torch is "emulated" by a relay contact.
« Reply #16 on: January 25, 2021, 08:45:27 AM »
I plan to use this one:
1 Canal Relays 5V 10A High und Low Level Trigger Optocoupler.
Hopefully that's the right one.
Still wondering how to connect as there are 3 pins each side.
