Hello Guest it is November 04, 2026, 10:15:01 AM
Author Topic: Loosing Y Axis position at the end of job.  (Read 14509 times)
kentdesautel
« on: April 06, 2006, 10:04:27 AM »
I am using Mach 3 and I am having problems sometimes after completing running a G-Code sequence the mill will not go back to the proper Home position...... the Y-Axis will normally be off.
In other words instead of going back to the home position it will be off roughly 1/4 inch.
The problem always seems to be with the Y-Axis
The Position on the screen shows "0" for all of the X-Y-Z Axis's for both the Machine and Tool postions.... but the Y-Axis will not be at the correct location.
Here is a sample set of code which this occurred:
G40 M6 T1
M7
G0 X2.302 Y0.919 Z0.1
G1 Z-0.01 F1
X2.327 Y0.919 Z-0.01 F2
Y1.081
X2.302
Y0.919
Y0.894
X2.351
Y1.106
X2.278
Y0.894
-------------- Lines removed to shorten post --------------
X0.673
G0 Z0.1
Y0.919
G1 Z-0.22 F1
X0.698 Y0.919 Z-0.22 F2
Y1.081
X0.673
Y0.919
Y0.894
X0.722
Y1.106
X0.649
Y0.894
X0.673
Y0.869
X0.747
Y1.131
X0.624
Y0.869
X0.673
Y0.844
X0.772
Y1.155
X0.599
Y0.844
X0.673
G0 Z0.1
X0 Y0
M02
Re: Loosing Y Axis position at the end of job.
« Reply #1 on: April 06, 2006, 10:16:20 AM »
Why don't you turn down the Accel for the y axis a bit and see if that helps.
www.newfangledsolutions.com
www.machsupport.com
