Hello Guest it is November 13, 2026, 10:01:26 AM
Author Topic: Wondering if anyone can help with a problem  (Read 7744 times)
« on: January 03, 2021, 05:46:55 PM »
Hi all thanks for letting me join this group.
I'm having a problem with a part I'm trying to cut, when it does the first depth of the profile cuts its good the second depth cut it gets off in the z positive direction and every cut is off by the same amount it also seems that my machine coordinates gets off each cut it makes.
I would appreciate any help I can get.
Thanks so much.
Mike
Re: Wondering if anyone can help with a problem
« Reply #1 on: January 03, 2021, 06:15:01 PM »
First thing that comes to mind is maybe the machine is binding up or hitting something. I have had it happen to me a few times where I will make a few cuts and the Z axis gets to its bottom hard stop and the cutter wont go any deeper so the stepper loses steps and nothing good happens from there.
« Reply #2 on: January 06, 2021, 08:24:40 AM »
Did you run calibration for that Axis ?-many Videos online to preform this
After that check back lash for the Axis ?
