Hello Guest it is November 13, 2026, 10:35:19 AM
Author Topic: external under pule frequency  (Read 9135 times)
« on: December 30, 2020, 03:54:17 PM »
             what am I missing? I have mach3 usb bob .The board lights up motors work.My limit switches are not working and my emergency switch is also
            not working.I have power at the board and there is power at the limit switch.when I look at my diagnostics page the word external show up under
             the pulse frequency is this normal
Offline TPS
  •  2,627 2,627
Re: external under pule frequency
« Reply #1 on: December 31, 2020, 12:14:20 AM »
can't see in my Magic glasball witch USB Controller you are using, but i think
Config -> Ports&Pins -> Input signals
are not set correctly (Port or Pin).
« Reply #2 on: December 31, 2020, 10:11:11 AM »
         the card has an eagle on it and its red the only name I could find is bitsensor.com
         The driver that I download to mach3 is RnRmotion
         I also used the 5 pin choices on one axis to try to get my limit switch to work
« Last Edit: December 31, 2020, 10:29:06 AM by dandreger »
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #3 on: December 31, 2020, 11:16:18 AM »
I think you will find that the inputs and outputs are on different port numbers. Do a search for bitsensor on the forum.
Make sure you use a genuine licence file, NOT the one that came with it.
https://www.machsupport.com/forum/index.php?topic=38895.msg271538#msg271538
« Last Edit: December 31, 2020, 11:19:44 AM by Graham Waterworth »
Offline TPS
  •  2,627 2,627
« Reply #4 on: January 01, 2021, 02:57:36 AM »
here:
https://buildyourcnc.com/item/electronicsAndMotors-electronic-component-breakout-Mach3-USB-Board
you can find a lot of Information how to wire/Setup Limit switches
