Hello Guest it is November 27, 2026, 09:20:51 AM
Author Topic: Some of my 3D reliefs in wood.  (Read 20029 times)
« on: December 27, 2020, 12:29:32 PM »
Wood carvings in diy cnc, some reliefs take 9-11hours to complete at 3500mm/min (137 inch/min).
https://www.youtube.com/channel/UCencrm5YnM-frz5gfJTYzNg/videos
Re: Some of my 3D reliefs in wood.
« Reply #1 on: December 28, 2020, 04:15:43 AM »
Great job! May I ask how long it takes usually to complete one project?
« Reply #2 on: December 29, 2020, 06:20:32 AM »
Hi, depend of what project.
For example with old stepper motors nema 23  the skull girl take 9hours at 3500mm/min XY and 1200 Z and the skull 4 hours aprox (only 3D finishing roughing passes are 3 and 1:30 hours).
With new motors (nema 24 closed loop hybrid), i finished to wiring new control box with csmio, closed hybrid motors nema24 and spindle with 50-75% more power (from kress fme router to teknomotor 1.1Kw spindle) i want to try to make it at 3500-4000mm/min XY and 2000-2400Z (maybe the tapered ball nose bit doesn't have enough resistance, but i need to try it because if i double Z speed its a lot of time of machining 30-50% depending of accelerations i think).
Offline ZASto
  •  434 434
« Reply #3 on: December 29, 2020, 09:07:34 AM »
Whenever you had coordinated motion which includes Z axis, your max speed would be 1200 mm/min, regardless of commanded 3500 mm/min. Coordinated motion is as fast as the slowest axis.
My personality is who I am.
« Reply #4 on: December 30, 2020, 08:02:39 AM »
I never noticed it, i thinking X,Y moved in full speed when no Z movement are involved.
In next try of 3D relieve i want to try the limits of the tapered ball nose bit and try double the speed or more.
