Hello Guest it is November 22, 2026, 02:25:39 PM
Author Topic: loop question with mach3  (Read 11668 times)
« on: October 07, 2007, 04:29:05 PM »
how do i get the "z" axis to drop .062" with each pass?  i can get the program to repeat as may times that i want to.  but i can not get the "z" to drop with each pass. please help.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: loop question with mach3
« Reply #1 on: October 08, 2007, 06:18:43 AM »
With in your loop add :-
G91 Z-.062
G90
Graham.
« Reply #2 on: October 08, 2007, 09:16:22 PM »
DID NOT WORK THE Z WOULD DROP TO -0.062 THAN IT WOULD RETURE TO THE PRESET PROGRAM.  HOW WAS I SUPPOSE TO ADD IT TO THE LOOP
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #3 on: October 08, 2007, 11:11:15 PM »
G---EEEE-ZZZZZ, LUTHER
WE CAN''T HEAR YOU!!!!!!!.
Why don't you post your G-code, Or take the "g## Z0" out of your G-code.
Good Luck, Chip
« Last Edit: October 08, 2007, 11:17:41 PM by afn09556 »
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
« Reply #4 on: October 17, 2007, 10:54:18 AM »
I have found that the easiest way  to do repetative things is to write a visual basic script. I have written several of these. I use DRO's to put in the information, such as start values, finish values, cut increments and lengths. The script takes the values I have put in the DRO's, e.g. start value 1 inch, finish value 1/2 inch, increment 20thou, length 3 inches. and then out puts the G Code to the lathe, each time taking the 20 thou cut until it arrives at the finish value.
It works very well and only take one command to implement it.
I have five of these Macro scipts for various little roughing out jobs which I can insert in any program at will. There is a guide to visual basic scripting in the video tutorials.
