Hello Guest it is November 13, 2026, 04:58:06 PM
Author Topic: Pokeys57cnc probe issue  (Read 29584 times)
« on: December 25, 2020, 08:29:33 AM »
Hello guys and Merry Christmas!!!!I have an issue with pokeys57cnc and Mach3.Trying to connect a touch probe and Im going crazy!I have connect one wire on the upper pin of limit switch connector (pin19 from the diagram) and the other at +5v,my board is Version 1.4 so as I see it doesnt need a pullup resistor.I made the settings in pokeys plugin from Mach 3 and the only im getting when i go to the Diagnostics tab of Mach3 is the Digitizing "led" blinking randomly.I also take a measurement of the physical pin19 on the board and its +5v without connecting anything.Please help!!!!   :-\
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Pokeys57cnc probe issue
« Reply #1 on: December 25, 2020, 12:18:26 PM »
What is pin 19 set up to do in the pokeys config?
It should be a digital input.
« Reply #2 on: December 26, 2020, 02:50:07 AM »
I have set it up as a digital input.I think I have sold the issue but it still seems a little weird.Let me explain...First of all one wire to physical pin 19 (probe input) and the other wire at Ground without a pullup resistor as my board is V1.4.Then in pokeys plugin through Mach3 I set the input 19 as probe input in Pulse Engine Settings tab and also in PokeysMapping tab.The weird thing is in Diagnostics tab of mach 3 the Digitize Led blinks randomly  without doing nothing but the probe works.If I go to pulse engine tab and put none in probe input but let the pin 19 as probe in Pokeyw Mapping tab then in diagnostics the led works fine,on when I touch the two wires off when they dont touch,but the Probe doesnt work,mach3 shows a message "No probe input".
« Reply #3 on: January 20, 2021, 09:06:59 AM »
I did the same setup as you and programmed the "Auto Zero Tool" button. It works fine for me.
Check the link to a Youtube video. I followed the instructions, but did not install the sound part of his VB script.
https://www.youtube.com/watch?v=tvV2Vmrxarc
