Hello
Guest
it is
November 13, 2026, 09:23:19 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach3 under Vista
Computer Crashes and will not Reboot
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Computer Crashes and will not Reboot (Read 12700 times)
JKMotorsports
5
on:
December 22, 2020, 05:55:55 PM »
After pulling my computer and Plasma Table out of storage after 2 years I reloaded Windows 7, Loaded Mach3 only. Rebooted after install and then proceeded to setup my inputs and outputs with no issues.
Overnight the computer shut off. Now when I try to boot the computer it just repeats the startup screen.
I've repeated this a few times with a few different builds of Mach3 and with the registry patches loaded through the CMD Prompt.
Any idea. I want to avoid changing any hardware if I can as when I stored it before my move everything worked great and I knew the ins and outs of the program/electronics on my build.
Logged
ZASto
434
Re: Computer Crashes and will not Reboot
Reply #1 on:
December 23, 2020, 10:49:48 AM »
Definitely it is your hardware problem.
Could be power supply, electrolytic capacitors on motherboard and, maybe, poorly seated cooler on CPU (likely needs a change of thermal paste).
Logged
My personality is who I am.
Print
Pages:
1
Go Up
« previous
next »
