Hello Guest it is October 22, 2026, 03:55:16 PM
Author Topic: Tip Direction in Turn?  (Read 19744 times)
« on: October 07, 2007, 01:48:28 PM »
Just in the closing stages of retrofitting my Lathe. I have been setting up the tool table with  X and Z offsets and tip radius but I am unsure of how the Tip Direction should be. As an example if I have a PCLNL tool in my turret should I enter 85degrees for the Tip Direction or would it be 95 degrees or possibly something else?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Tip Direction in Turn?
« Reply #1 on: October 08, 2007, 06:30:40 AM »
Hi Hood,
this is how the tool tip works.
Graham.
« Reply #2 on: October 08, 2007, 02:17:15 PM »
Thanks for the reply Graham but afraid I dont really follow. Not long in from work so maybe I just need to have a cup of tea and look again :D
  •  2,785 2,785
« Reply #3 on: October 08, 2007, 04:47:24 PM »
I was at work when I saw your post, so time was short.
If you look at the 'V' shape created by the divisions then they look like the point of a tip, the 'V' created by 8 and 3 would be a normal o/d turning tool.
So :-
O/D moving right to left is direction 3
                 left to right                 4
I/D             right to left                 2
                 left to right                 1
O/D using a button tool                 8
I/D     "         "        "                    6
Is that more understandable  :)
Graham.
« Reply #4 on: October 08, 2007, 05:00:26 PM »
Yes thanks Graham, think my problem was I thought it was looking for a number in degrees rather than a code.
  •  2,785 2,785
« Reply #5 on: October 08, 2007, 05:12:20 PM »
By the way, they only have an effect when you use tool comp. Also they can be a pain to use, if you go down a bore with something like :-
G00 X27. Z1.
G01 G41 Z0 F.15
X25. Z-1.
Z-25.
G00 Z1.
G40
Then the tip will smash and scrap the part as you have changed direction the tool jumps to the other side of the line and digs into the bore.
This method is safer.
G00 X27. Z1.
G01 G41 Z0 F.15
X25. Z-1.
Z-25.
X23.
G00 G40 Z1.
Also, NEVER do grooving using tool comp.
Graham.
« Last Edit: October 08, 2007, 05:15:28 PM by Graham Waterworth »
« Reply #6 on: October 08, 2007, 05:16:43 PM »
Ha ha, thanks Graham, looks like I am going to have a load of broken tools just shortly :D
  •  2,785 2,785
« Reply #7 on: October 08, 2007, 05:18:28 PM »
Graham.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #8 on: October 08, 2007, 11:24:58 PM »
Hi, Graham
Is this for an Aft tool post ?
Thanks, Chip
  •  2,785 2,785
« Reply #9 on: October 09, 2007, 03:48:42 AM »
Hi Chip,
On an industrial machine it makes no difference which tool post as everything is rotated around the centre line in the software.
Front tool post tools cut on top, rear tools cut underneath.
As for mach3, not 100% sure as I have not tried it, but I will and report back.
Graham.
