Hello Guest it is September 20, 2026, 09:37:24 PM
Author Topic: CSMIO IP-M Z touch plate wiring  (Read 28143 times)
« on: December 20, 2020, 12:56:49 PM »
Hi to all,
First thanks for your time and help.
I started to make a new controller box for migrate from GRBL to CSMIO IP/M and i have one doubt and i don't want to try things without understand it.
I have one simple touch plate with a clamp for a bit, but I'm afraid of make a bad use.
The problem i have I'm afraid of use pins IN 12 (11+ input pin) and IN25 (11- input Pin) with the chassis/spindle because are grounded to house earth and i don't know if this is possible.
I put this little schematic if someone can confirm how i need to wire the touch plate with clamp (or chassis without clamp) and confirm the pins used.
This thing it's the only i need for finish the controller box and continue to use my cnc.
Thanks to all i really appreciate your help and experience.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: CSMIO IP-M Z touch plate wiring
« Reply #1 on: December 20, 2020, 04:43:33 PM »
Cs-Labs have connection diagrams on the site.
https://en.cs-lab.eu/tool-length-sensor-gnd-on-a-machine/
« Reply #2 on: December 20, 2020, 06:11:08 PM »
Thanks for your help,
It's necessary use second 24v PSU?
