Hello Guest it is November 24, 2026, 03:58:06 PM
Author Topic: macro external center piece  (Read 21024 times)
« on: December 20, 2020, 03:53:27 AM »
Buongirno
I use this macro for full center piece (modified to my needs by TPS) I would like to make some changes:
add double tap as it is not in my capacity.
I thank those who can help me.
  Rem VBScript To center probe outside diameter Metric Version
Speak (" psizionarsi CINQUE millimetri sopra il pezzo") 'Avviso Vocale
response = MsgBox ("   5 mm    SOPRA IL PEZZO")
  Begin Dialog ButtonSample 250,200,120,60,"   CENTRO PEZZO PIENO ? "
   OKButton 12,20,40,14
   CancelButton 68,20,40,14
End Dialog
Dim Dlg2 As ButtonSample
Button = Dialog (Dlg2)
If Button = 0 Then
   MsgBox "CENTRO PEZZO CANCELLATO !"
    Speak ("     CENTRO        PEZZO      CANCELLATO") 'Avviso Vocale
   Exit Sub
End If
Sleep (1000) ' pausa di 1 secondi
Speak (" CONFERMARE centro pezzo pieno") 'Avviso Vocale
Message "INIZIO CENTRO PEZZO PIENO"
response = MsgBox ("CONFERMARE CENTRO PEZZO PIENO")
 Message "**** zero assi ****"
   DoOEMButton (1008) 'zero X
   DoOEMButton (1009) 'zero Y
   DoOEMButton (1010) 'zero Z
   Sleep (2000) ' pausa di 1 secondi
Speak ("ZERO assi completato") 'Avviso Vocale
CurrentFeed = GetOemDRO(818) 'Get the current feedrate to return to later
CurrentAbsInc = GetOemLED(48) 'Get the current G90/G91 state
CurrentGmode = GetOemDRO(819) 'Get the current G0/G1 state
CurrentToolDiameter = GetOemDRO(1000) 'gets the current tool diameter
If GetOemLed (825) <> 0 Then 'Check to see if the probe is already grounded or faulty
    Call ProbeGrounded()
    Exit Sub
Else
    XCurrent = GetDro(0)
    YCurrent = GetDro(1)
    OutsideDiameter = GetUserDRO(1152)
    Code "G4 P1" 'Pause 1 second to give time to position probe plate
    While IsMoving ()
    Wend
    Call SetDro (0,0.000)
    While IsMoving ()
    Wend
    Call SetDro (1,0.000)
    Code "F50" 'slow feed rate to 100mm/sec
    Code "G90 G0 X" &XNew + OutsideDiameter * .6
    Code "G91 G0 Z-10"
Rem Probe Left
    XNew = Xcurrent - 75
    Code "G31 X" &XNew
    While IsMoving() 'wait for the move to finish
    Wend
    XPos1 = GetVar(2000) 'get the probe touch location
    Code "G91 G0 X2"
    Code "G91 G0 Z10"
    Code "G90 G0 X" &XCurrent 'rapid move back to start point
    Code "G91 G0 X" &XCurrent - OutsideDiameter * .6
    Code "G91 G0 Z-10"
Rem Probe Right
    XNew = XCurrent + 75 'probe 75mm to right
    Code "G31 X" &XNew
    While IsMoving()
    Wend
    XPos2 = GetVar(2000)
    Code "G91 G0 X-2"
    Code "G91 G0 Z10"
    XCenter = (XPos1 + XPos2) / 2 'center is midway between XPos1 and XPos2
    Code "G90 G0 X" &XCenter 'rapid move to the x center location
    While IsMoving ()
    Wend
    Code "G4 P0.25"
    Code "G90 G0 Y" &YNew - OutsideDiameter * .6
    Code "G91 G0 Z-10"
Rem Probe up
    YNew = YCurrent + 75
    Code "G31 Y" &YNew
    While IsMoving()
    Wend
    YPos1 = GetVar(2001)
    Code "G91 G0 Y-2"
    Code "G91 G0 Z10"
    Code "G90 G0 Y" &YCurrent
    Code "G91 G0 Y" &YCurrent + OutsideDiameter * .6
    Code "G91 G0 Z-10"
Rem Probe down
    YNew = YCurrent - 75
    Code "G31 Y" &YNew
    While IsMoving()
    Wend
    YPos2 = GetVar(2001)
    Code "G91 G0 Y2"
    Code "G91 G0 Z10"
    YCenter = (YPos1 + YPos2) / 2
Rem move To the center
    Code "G90 G0 Y" &YCenter
    While IsMoving ()
    Wend
    While IsMoving ()
    Wend
    Call SetUserDro (1152,YPos2 - YPos1 - CurrentToolDiameter)
    Code "G4 P0.25"
    Code "F" &CurrentFeed 'restore starting feed rate
   Call ReturnG90G91State()
   Exit Sub
End If
Offline TPS
  •  2,627 2,627
Re: macro external center piece
« Reply #1 on: December 29, 2020, 12:45:43 AM »
what do you mean with double tap?
« Reply #2 on: December 29, 2020, 01:05:38 AM »
Good morning
by double touch I mean that once the probe touches the piece it moves backwards by 2mm and then slowly touches the piece for the second time obtaining the most accurate measurement
I hope I explained myself (translated with google)
thanks TPS
Offline TPS
  •  2,627 2,627
« Reply #3 on: December 29, 2020, 01:45:11 AM »
Code: [Select]
End Dialog
If Button = 0 Then
   Exit Sub
End If
    Exit Sub
Else
    While IsMoving ()
    Wend
    While IsMoving ()
    Wend
    Code "G91 G0 Z-10"
Rem Probe Left
    Code "G31 X" &XNew
    Wend
    Code "G91 G0 X2 F10"
    Wend
    Code "G31 X" &XNew
    Wend
    Code "G91 G0 X2 F50"
    Code "G91 G0 Z10"
    Code "G91 G0 Z-10"
Rem Probe Right
    Code "G31 X" &XNew
    While IsMoving()
    Wend
    Code "G91 G0 X-2 F10"
    Wend
    Code "G31 X" &XNew
    Wend
    Code "G91 G0 X-2 F50"
    Code "G91 G0 Z10"
    While IsMoving ()
    Wend
    Code "G4 P0.25"
    Code "G91 G0 Z-10"
Rem Probe up
    Code "G31 Y" &YNew
    While IsMoving()
    Wend
    Code "G91 G0 Y-2 F10"
    Wend
    Code "G31 Y" &YNew
    Wend
    Code "G91 G0 Y-2 F50"
    Code "G91 G0 Z10"
    Code "G91 G0 Z-10"
Rem Probe down
    Code "G31 Y" &YNew
    While IsMoving()
    Wend
    Code "G91 G0 Y2 F10"
    Wend
    Code "G31 Y" &YNew
    Wend
    Code "G91 G0 Y2 F50"
    Code "G91 G0 Z10"
    While IsMoving ()
    Wend
    While IsMoving ()
    Wend
    Code "G4 P0.25"
   Exit Sub
End If
« Reply #4 on: December 29, 2020, 02:44:29 AM »
the modification works great !!!
if I don't ask too much is it possible to separate axes?
I mean having 2 macros, one for x axis (always x for full)
one for y axis (always for full)
I sincerely thank you for the help given
Offline TPS
  •  2,627 2,627
« Reply #5 on: December 29, 2020, 03:32:05 AM »
X-Axis
Code: [Select]
Rem VBScript To center probe X-Axis
End Dialog
If Button = 0 Then
   Exit Sub
End If
    Exit Sub
Else
    While IsMoving ()
    Wend
    While IsMoving ()
    Wend
    Code "G91 G0 Z-10"
Rem Probe Left
    Code "G31 X" &XNew
    Wend
    Wend
    Code "G31 X" &XNew
    Wend
    Code "G91 G0 Z10"
    Code "G91 G0 Z-10"
Rem Probe Right
    Code "G31 X" &XNew
    While IsMoving()
    Wend
    Wend
    Code "G31 X" &XNew
    Wend
    Code "G91 G0 Z10"
    While IsMoving ()
    Wend
    Code "G4 P0.25"
   Exit Sub
End If
Y-Axis
Code: [Select]
Rem VBScript To center probe Y-Axis
End Dialog
If Button = 0 Then
   Exit Sub
End If
    Exit Sub
Else
    While IsMoving ()
    Wend
    While IsMoving ()
    Wend
    Code "G91 G0 Z-10"
Rem Probe up
    Code "G31 Y" &YNew
    While IsMoving()
    Wend
    Wend
    Code "G31 Y" &YNew
    Wend
    Code "G91 G0 Z10"
    Code "G91 G0 Z-10"
Rem Probe down
    Code "G31 Y" &YNew
    While IsMoving()
    Wend
    Wend
    Code "G31 Y" &YNew
    Wend
    Code "G91 G0 Z10"
    While IsMoving ()
    Wend
    While IsMoving ()
    Wend
    Code "G4 P0.25"
   Exit Sub
End If
« Reply #6 on: December 29, 2020, 04:35:47 AM »
the macros work well the only thing that in the measurement is 1mm less, I mean the piece is 80mm in the 79mm dro
I tried to insert +1 in the line:
  Call SetUserDro (1152, YPos2 - YPos1 - CurrentToolDiameter)
modified
  Call SetUserDro (1152, YPos2 - YPos1 - CurrentToolDiameter +1)
and that's okay but I don't know if it's a legitimate thing!!
