Hello Guest it is October 30, 2026, 07:25:11 PM
Author Topic: (Mach4) wxLathe TouchScreen Friendly Version  (Read 24411 times)
Offline SimonRafferty
  •  46 46
  • Movie SFX Design Engineer
« on: December 19, 2020, 06:12:46 AM »
The touch screen on my Lathe is fairly small (11") and I was struggling to see the text on buttons / controls.  Also, my fingers are big enough to press several buttons at the same time.
This is the standard wxLathe screen with the buttons enlarged, moved around a bit (to suit the way I like to use it) and the text size increased to make it all more readable.
I've removed some of the controls I tend not to use to make more space.
I've only made one small change to the page load script to make it run, having removed a control it referenced (spindle ratio).  Other than that, everything is as standard.
I've been using it for a couple of weeks, making tweaks here & there - but it seems to be OK.  Let me know if you find otherwise or if you think of a better way of doing something!
  •  9,375 9,375
Re: (Mach4) wxLathe TouchScreen Friendly Version
« Reply #1 on: December 19, 2020, 06:24:36 AM »
Looks good.
