Hello Guest it is November 19, 2026, 05:16:34 AM
Author Topic: mach 3 for cnc plasma table  (Read 20635 times)
« on: December 18, 2020, 11:15:18 PM »
hello i'm new to this and have recently been using my new plasma table and I went today to try to cut something out and followed the process from designing in via cad, importing as dxf file and then uploading into sheetcam to convert to G-code. When uploading g code into mach 3 i got a code on the bottom that said "Bad Character used block = 0), at first i thought it was just the g code i had just made but it does it with existing g codes that i have already cut and saved, please help me out thank you
Offline TPS
  •  2,627 2,627
Re: mach 3 for cnc plasma table
« Reply #1 on: December 19, 2020, 12:34:54 AM »
pls post oene of those G-code files.
« Reply #2 on: December 19, 2020, 08:43:26 AM »
Not sure how to add a photo of the g code to this
  •  9,378 9,378
« Reply #3 on: December 19, 2020, 09:02:45 AM »
You need to attach the Gcode file (not a photo).
This thread details how to add attachments to the forum posts; https://www.machsupport.com/forum/index.php?topic=24585.0
