Hello Guest it is October 25, 2026, 03:16:13 AM
Author Topic: Mach4 Lathe - which motion controller?  (Read 15367 times)
Offline SimonRafferty
  •  46 46
  • Movie SFX Design Engineer
Re: Mach4 Lathe - which motion controller?
« Reply #10 on: January 05, 2021, 12:50:30 AM »
Thanks for all your help.
I had pretty much narrowed it down to PDMX or HiCON but then, decided to buy a CSMIO-IP/S.
The reasons were mainly faster delivery (to the UK) and cost.  Also, since the machine was already running CSMIO-IP/M, the re-wiring would be minimal.  In practice it only took 30 mins to get it up & running.
So far, it looks good.  My problem with jerky servos has vanished.  I think the IP/M couldn't deliver pulses fast enough.
The only negative seems to be that it doesn't (obviously) control the spindle as a servo - just as a simple VFD.  It clearly has some speed regultion / calibration inside, as the spindle speed is spot on but it's not regulating it on the fly so the speed changes with load.
Rigid tapping works OK with small taps - but because there's no speed regulation, it's easy to stall the spindle on larger ones.  I'll have to see if I can tweak the servo parameters to fix it.
My next machine will be HiCON though for certain!
« Reply #11 on: January 05, 2021, 01:14:18 AM »
it seems to me you can control the spindle with step / dir signal via OB output. ask cslab for confirmation. what plugin have you installed? I have on the 3.205 I am fine. 3.305 was giving me system stability problems.
  •  46 46
« Reply #12 on: January 05, 2021, 03:06:21 AM »
You're right, you can - and that's what I use on my Mill.  However, my servo spindle controller is an old Fanuc which only has 0-10V + Direction.
I talked to CS - and they said it was impossible.  Unfortunately, I don't believe in impossible!
Si
« Reply #13 on: February 01, 2021, 01:50:34 PM »
I'm running an ESS on mine with no issues.
