Hello Guest it is September 19, 2026, 10:47:52 PM
Author Topic: Spindle Setup  (Read 7702 times)
Spindle Setup
« on: December 13, 2020, 04:02:27 PM »
Hi
I am setting up my machine I built and am having issues turning the spindle on. When I press "Spindle CW/Stop" the spindle will turn on for a few seconds and then turn off and the Enable starts flashing. It has this in the log file:
API: mcSpindleSetDirection(inst = 0, dir = 1) (unknown caller)
2020-12-13 15:52:13.369 - Signal id 1142, (Spindle Fwd), changed from LOW to HIGH.
2020-12-13 15:52:13.369 -    >>> ESS: PWM Mode - 'Spindle Motor Dir' set to Forward.
2020-12-13 15:52:13.369 - >>> ESS: Pwm Duty Cycle Zero At Min RPM Mode.  Range RPM: 7200.00 MIN, 24000.00 MAX
2020-12-13 15:52:13.369 - Signal id 1141, (Spindle On), changed from LOW to HIGH.
2020-12-13 15:52:13.369 - >>> ESS: Setting spindle to 20000.0 RPM or 76.2%. Range 0 PWM Base Freq = 400
2020-12-13 15:52:13.370 -        ESS: Activating output Port1-Pin16 - {P1-16}
2020-12-13 15:52:13.370 - >>> ESS: Spindle PID is not enabled.
2020-12-13 15:52:13.416 - >>>ESS: 260 - Limit Switch trigger on Motor Limit 2++
2020-12-13 15:52:13.416 - >>>ESS: 260 - Limit Switch trigger on Motor Limit 2--
2020-12-13 15:52:13.593 -    ####### ESS Reset Velocity C
2020-12-13 15:52:13.619 -    ####### ESS Reset Velocity C
2020-12-13 15:52:13.648 - API: mcMotionClearPlanner(inst = 0) (Called by ESS)
2020-12-13 15:52:13.648 - API: mcMotionSync(inst = 0) (Called by ESS)
2020-12-13 15:52:13.648 - SyncPosition()! Clearing planner.
2020-12-13 15:52:13.649 - >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
2020-12-13 15:52:13.649 - >>> ESS: A spurious limit_hit_latch event occurred due to a transient on a limit switch.
2020-12-13 15:52:13.649 - >>> If this continues, fix your switch or add more noise filtering to the limit switch shown above.
2020-12-13 15:52:13.649 - >>> Clearing limit_hit_latch now, and disabling Mach4.
I have the following parts/machine/settings
Spindle, 2.2kw liquid cooled amazon special with a
Inverter: Huanyang inverter 220VAC Single Phase
Ethernet Smoothstepper with C11G breakoutboard
Let me know if I need to post settings
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Spindle Setup
« Reply #1 on: December 13, 2020, 08:49:06 PM »
Disable your limit switches and see if the spindle runs better,  if so it may be noise on the limit switches.
