Hello Guest it is November 22, 2026, 10:03:23 PM
Author Topic: Stepper motor calculated steps have changed.  (Read 6969 times)
« on: December 13, 2020, 03:11:15 PM »
The driver board switches are set to 1/16  and should result with X axis 320 steps, but in auto Settings it has set the steps to 160 This suddenly happened after re down loading Mach3 ( had been fine for 7 years) This has resulted in less detailed machining. I have now replaced the computer running the same Windows 7, this was done by an IT guy I know and issue has remained the same Has anyone any idea how to fix this?
