Hello Guest it is November 22, 2026, 01:38:16 PM
Author Topic: Charge pump ??? No analog voltage anymore  (Read 11193 times)
« on: December 10, 2020, 11:33:50 AM »
In Mach4 for what are they referring to when they mention charge pump1 charge pump 2.
Is that to start water cooling or something?
And when I type in m03 s5000 and then cycle start AG/AO would light up and give a voltage. It no longer does this I uninstalled mach4 and tried it again same thing.
I only have 24v in connected to the board no other wires.
Also when I hit cycle start N03/Y101 light up as they did before but no AG/AO.
THIS occurred around the same time I connected the N03/Y101 to the vfd.
Thank you for your help
