Hello Guest it is October 21, 2026, 12:54:54 AM
Author Topic: Mach3 custom macro with value question  (Read 8391 times)
« on: December 08, 2020, 03:46:50 AM »
Hi all,
I have a lathe with 2 vfd's one for the spindle and one for a livetool, I use a custom macro M133 to activate an output that then goes via modbus to the livetool inverter, the speed for the livetool I take from the spindle DRO, as the spindle does not work while in C axis mode, I have an electrical clutch that connects a nema 34 to the C-axis - all this works just fine.
But, the spindle have a max rpm, and the livetool a higher rpm, is there anyway to say I could do something like this:
M133 P2500
that "P" value could be another rpm register, or just take that value to the M133 and set in in there?
Regards Morten
Offline TPS
  •  2,627 2,627
Re: Mach3 custom macro with value question
« Reply #1 on: December 08, 2020, 04:26:07 AM »
RPM = Param1()
within the macro will read the value from P Parameter
if you call
Code: [Select]
M133 P2500
and in the macro:
Code: [Select]
RPM = Param1()
the RPM will be 2500
see:  www.machsupport.com/wp-content/uploads/2013/02/Mach3_V3.x_Macro_Prog_Ref.pdf
« Last Edit: December 08, 2020, 04:28:39 AM by TPS »
« Reply #2 on: December 08, 2020, 09:57:20 AM »
Working, thanks again TPS ;)
Regards Morten
