Hello Guest it is October 10, 2026, 05:00:28 PM
Author Topic: Mach3 moving a axis that it’s not in the program  (Read 6576 times)
Offline rasta
  •  32 32
« on: December 02, 2020, 12:27:05 AM »
Hi , I wonder if someone has had the same problem than me today .
Loaded a simple Milling 2 1/2 D program that is using X , Y , And Z axis .The program works ok , until I pressed the feed hold button , the feed stops , and then when I press the cycle start again Mach3 select the 4 axis in place of the axis that was moving before I pressed the feed hold , this does not happen if instead of using the feed hold button I use the stop button.. Using Mach3 , with the ESS.. on win7
Regards
Mariano
