Hello Guest it is November 23, 2026, 10:39:55 AM
Author Topic: Mach 3 only loading little bit of Gcode  (Read 13811 times)
« on: November 26, 2020, 08:00:53 PM »
Hello,
New to Mach 3 & having problem with opening or running Gcodes.  Create gcode in fusion 360 & post.  Loads, displays tool path & simulates cut on Mach 3 on laptop where fusion is, all good. Copy & load gcode file into Mach 3 on pc with CNC attached.  Only shows small portion of pic on table display, example half a letter of sign, gcode window on left seems to show entire code but doesn’t display in tool path on table view.  Does this on any gcode loaded but if code is typed directly into MDI screen or created with Mach 3 wizard displays & works fine.  Have done many uninstalls & reinstalls of Mach 3, double/triple checked all settings etc.  Only weird thing noticed was all gcode displays correctly when ncusbpod.dll for USB controller is NOT installed, but obviously CNC doesn’t operate, as soon as I put ncusbpod.dll file into Mach 3 it all goes to hell again.  Basically all good until USB driver is installed.  Please help, I don’t understand what is going on.  Why when I test with no USB driver installed all good in Mach 3 but no CNC control, with USB driver installed have CNC control but no good Mach 3 display of code.  Any suggestions? Have already wasted last 4 days on it :-(
Cheers from tassie legends
  •  9,378 9,378
Re: Mach 3 only loading little bit of Gcode
« Reply #1 on: November 27, 2020, 12:39:03 AM »
Mach3 when running in Demo mode and with the drivers installed will only load and run the first 500 lines of Gcode.
You need to purchase and install a license which is available from here; https://www.machsupport.com/shop/mach3/
« Reply #2 on: November 27, 2020, 01:04:16 AM »
Thanks for reply Tweakie,  I have come to that conclusion also.  Thing is I just bought the entire setup (CNC, pc & full licensed Mach 3) second hand & doesn’t say demo up top, has blokes name.  Looks like I have been conned :-(  should I bother paying for Mach 3 license now it is obsolete & unsupported or just go to Mach 4?  Only doing hobby woodworking for fun.
Offline TPS
  •  2,627 2,627
« Reply #3 on: November 27, 2020, 01:09:46 AM »
you can try this:
https://www.youtube.com/watch?v=JquPpIab4GY
maybe it help's
  •  9,378 9,378
« Reply #4 on: November 27, 2020, 02:28:01 AM »
Hi Woodworkermark,
I have sent you a PM.
« Reply #5 on: November 27, 2020, 02:56:51 AM »
Thanks TPS, No not that, I don’t get this error message, thanks for reply anyway.  Looks like I will just have to get license, even though I thought I already had one ... lol
« Reply #6 on: November 27, 2020, 02:58:09 AM »
Thanks Tweakie,  I have replied to PM ... I think
  •  9,378 9,378
« Reply #7 on: November 27, 2020, 05:47:16 AM »
Yep, you sent the PM reply correctly.
Which of the XHC motion controllers are you using and do you have their latest Mach3 ncusbpod.dll ?
Offline TPS
  •  2,627 2,627
« Reply #8 on: November 27, 2020, 06:34:24 AM »
i think the latest Version can be found here:
https://www.nvcnc.net/xhc-cnc-controller.html
but not 100% sure.
