Hello Guest it is October 20, 2026, 09:41:44 PM
Author Topic: Mach 3 tolerance problem  (Read 10536 times)
« on: November 24, 2020, 04:08:46 AM »
Hello,
I'm useing Mach3 and CSMIO IP-S controllers on lathe. I'm using it for serial production parts.
The problem is that it doesn't hold part dimensions. I have try to run with and without backlash compensation, but problem say the same.
However it is working great for around 20parts, than jumps for around 0,04mm and so on.
I really kindly ask anyone to help me with that, as I'm really desperate. I need machine to run but I don't know what to do.
Thank you
Gasper
Re: Mach 3 tolerance problem
« Reply #1 on: November 25, 2020, 12:24:03 AM »
Anyone please...
  •  9,374 9,374
« Reply #2 on: November 25, 2020, 02:01:47 AM »
Can you please .zip and post your problem Gcode file.
« Reply #3 on: November 25, 2020, 02:52:51 AM »
Here is Gcode of actual part
« Reply #4 on: November 25, 2020, 02:53:23 AM »
Gcode atached
Offline TPS
  •  2,627 2,627
« Reply #5 on: November 25, 2020, 12:35:35 PM »
CSLAB recomends to use  R3.043.022 with their Controllers.
PLS Try this Version (fresh copy).
ftp://ftp.machsupport.com/Mach3/
from CSLAB Homepage:
...., it’s enough to install older Mach3 release (03.043.022 to 03.043.044). I recommend 03.043.022 release. It’s the most reliable in our opinion. It’s here: ftp://www.machsupport.com/Mach3/Mach3Version3.043.022.exe
 Run the installer and re-instal it (it will replace the version you have).
« Last Edit: November 25, 2020, 12:43:32 PM by TPS »
