Hello Guest it is October 21, 2026, 10:49:51 AM
Author Topic: Unable to run x,y or z access.  (Read 8887 times)
« on: November 23, 2020, 06:28:03 PM »
I have been running fine on win10 with my 3018MX3 and mach3.  I purchased a license and started with this software in June and have been using it ever since.  Last night I shut down my pc and cnc and when I returned to it today I am unable to control any movements. I can still however manually turn on my spindle motor.
Does anyone have any ideas? Anything else you need to help me troubleshoot.
  •  9,374 9,374
Re: Unable to run x,y or z access.
« Reply #1 on: November 24, 2020, 12:42:29 AM »
You may have acidentally corrupted your .xml profile. Try returning to an earlier profile which was working correctly. Operator / Restore Settings  (follow on-screen directions)
« Reply #2 on: November 24, 2020, 09:24:30 AM »
Thank you for the reply,   i had to go in and rebuild the output ports,  I wish I would have seen this before unhinging everything, I think I am back up.   I even had to recalibrate everything.  Let's see how it goes today.
« Reply #3 on: November 24, 2020, 02:02:33 PM »
SO my rebuild apparently is wrong, my product is now being carved undersize.  when I try a restore I get error found, Art code 9991, attempt recovery?  and then when I click yes it triggers the same message.  error triggered.
  •  9,374 9,374
« Reply #4 on: November 25, 2020, 12:03:33 AM »
Run the Axis Calibration feature (Settings page) just to check that you have your Steps per Unit set correctly for each axis.
