Hello Guest it is October 20, 2026, 02:50:58 PM
Author Topic: PWM vs Analog output for spindle control?  (Read 11531 times)
« on: November 22, 2020, 03:13:26 PM »
I have a G0704 cnc that I built about 8 years ago.  It uses mach3, an ethernet smooth stepper and a C11g  breakout board.
For the spindle I'm using a 1.5hp bldc motor and a GlockCNC 1200 watt 1200WBD driver. The speed is controlled via the C11g breakout boards onboard 0-10v Analog converter, connected to the 1200WBDs Analog input terminals.  The breakout board converts PWM into a 0-10v Analog signal.
My spindle works well enough,  but either the Analog converters output isn't very linear, or the 1200WBD driver doesn't convert the voltage to RPM in a linear manner.
I can easily tune the spindle speed to match the mach3 commanded speed using the C11g onboard potentiometer,. But it only ever matches @ that specific speed.  For example, if I enter 4000rpm into mach3, and adjust the potentiometer untill I have 4000 RPM at the spindle, entering 3000rpm in mach3 will get me about 2700rpm at the spindle.  The closer I get to 4000, the better they match.  Above 4000, they will start to diverge again.    This same non-linearity manifests no matter which RPM I use as the base for tuning.
My 1200WBD can also accept a 5v 1khz-2khz PWM signal to control the speed via PWM duty cycle.
My question is:. If bypass the 0-10v converter, and feed the PWM signal directly to the 1200BWD driver and use PWM duty cycle to control the speed, would I get better linearity?
It's not difficult to bump the commanded RPM up/down untill the tachometer is where I want,. But it would be nice if I didn't have to do that.
Offline TPS
  •  2,627 2,627
Re: PWM vs Analog output for spindle control?
« Reply #1 on: November 23, 2020, 04:23:36 AM »
are you sure your pullex Settings match to the real Speed of your spindle?
« Reply #2 on: November 23, 2020, 08:33:18 AM »
I believe so.
My motor is a 1-1 ratio belt drive BLDC 1.5hp 8000rpm.   My index pulse tachometer is an optical trigger with 2 slots.
My pulley setup in mach 3 is min=0, max=8000, ratio=2
The actual RPM read by mach 3 from the pulse card matches the RPM read by my motor driver perfectly.
« Reply #3 on: November 23, 2020, 05:05:44 PM »
I doubt it, the non linearity is largely because the controller is actually a 'phase controlled rectifier bridge' and the transfer function ( the mathematical description
of the output verses the input) is highly non-linear with phase controlled bridges. It is in fact approximately linear to sin2 over a range of 0 to 90 degrees.
Is precise speed control that important?  For years a and years we used manual mills and lathes which which not adjustable so had to accommodate whatever gear
ratio that was available.....so why the fixation on spindle speed now?
« Reply #4 on: November 23, 2020, 08:04:16 PM »
Thanks for the reply, that's the info I was looking for and approximately what I expected.
It's not so much a fixation with spindle speed, more a mild nagging curiosity.  I get by fine with it as-is.
The reason I decided to explore it further, is because while reading the bldc driver manual, I realized the same terminals are used for both Analog and PWM inputs.   Bypassing the Analog would be a simple matter of moving two wires on the breakout board and changing a setting in the bldc driver.  I wouldn't have to do anything to the wiring harness.
Thanks for the response.
