Hello Guest it is November 23, 2026, 12:12:10 PM
Author Topic: Vfd power safety output  (Read 6593 times)
Offline DAAD
  •  105 105
« on: November 22, 2020, 06:56:47 AM »
Hello,
Because my spindles are setup on a second control box i would like to add a safety feature in my m6 macro.
I would like it to check if there is power on the vfd, but honestly i would not know where to start or whats done best in this situation.
I would like to rule out operation error if someone forgets to power on the spindles...
Is there a signal i can "get" from the vfd this way i can program an input around this that needs to be checked before the gcode can start.
Keep Safe,
Adam
Re: Vfd power safety output
« Reply #1 on: November 22, 2020, 05:43:08 PM »
actualy this question is more for yours VFD supplier
but i think every vfd supplier have the OK output ,its mean no any error
by the way SCM (italy brand) have also one more safty device in there M6 that cheack if the 3 coil on the spindle are conect
Offline DAAD
  •  105 105
« Reply #2 on: November 23, 2020, 10:55:11 AM »
Ok!
Will look into the vfd manual for an "OK" output!
Thanks for pointing me in the correct direction!
Offline DAAD
  •  105 105
« Reply #3 on: November 27, 2020, 08:06:41 AM »
I was able to get an input for the VFD to mach' and have adjusted my cycle start so i can't start without power onto the spindles.
Thanks for the tip!
Keep Safe,
Adam
