Hello Guest it is October 21, 2026, 07:01:46 AM
Author Topic: Mach 3 Screen Lockout Buttons/Customize  (Read 8771 times)
« on: November 12, 2020, 09:41:55 AM »
Is there any way I can customize or lockout certain buttons on the Mach 3 screen? For example, I would need full access to all of the buttons/menu items when troubleshooting/debugging. However an operator running the machine in production would only need access to the cycle start/stop, pause, load g-code buttons. Since there are so many buttons and menu items, the operator could easily press something by accident and cause a mess. I would like to prevent this from happening.
Thanks in advance!
Offline TPS
  •  2,627 2,627
Re: Mach 3 Screen Lockout Buttons/Customize
« Reply #1 on: November 13, 2020, 01:33:26 AM »
have you tryed the Operator -> Lock and Operator -> Unlock ?
this is only for menuu functions, the rest Needs to be done with a customized screenset.
« Reply #2 on: November 16, 2020, 12:12:30 PM »
No I haven't tried the operator lock/unlock. I see there is a password to lock it out. Is it a default password?
Offline TPS
  •  2,627 2,627
« Reply #3 on: November 16, 2020, 02:39:17 PM »
if you lock, you "define" your pasword to unlock
