Hello Guest it is November 10, 2026, 01:54:06 AM
Author Topic: Dosen't see change  (Read 11842 times)
Offline Ben
  •  79 79
Dosen't see change
« on: October 05, 2007, 08:46:29 AM »
Dim Val
Val = GetOemDro(83)
Call SetOemDro(150,Val)
This gets the current X position and writes it to softlimit Max X but the program dosen't recognize it until I click Config/Homming/limits. I thought the softlimits toggle would cause the program to look there for new info.
Offline Ben
  •  79 79
Re: Dosen't see change
« Reply #1 on: October 07, 2007, 10:32:49 AM »
I also tried to use OEM 340 & 341 (Temp set softlimits min and max) and nothing happens. I see no change in the config/homming/limits table. I've read all the Wiki stuff and don't see any command to update the system, I don't know what else to try. Thanks for stopping by.
« Reply #2 on: October 07, 2007, 08:03:09 PM »
Hey Ben, I don't think you will be able to do this. Obvioulsy you can get and update the values, but it is a setting, kinda like motor tuning, it isn't meant to be changed on the fly. Seems like I saw a post from you about the config. changing often. I think you may want to look at having specific profiles set up. Sorry if I'm misunderstanding you.
Offline Ben
  •  79 79
« Reply #3 on: October 07, 2007, 08:47:42 PM »
Brett, Thanks for the reply. I think you must be right so I'll just move on to another project. Thanks again. Ben
« Reply #4 on: October 07, 2007, 08:50:59 PM »
No problem Ben. I see one of the Gurus looking at the thread now, maybe he can confirm this for us.
Offline Ben
  •  79 79
« Reply #5 on: October 09, 2007, 10:29:57 AM »
This is my screen for setting softlimits To use this I move the work to the area where there is anĀ  interference and click the appropriate set button. . The only drawback is you have to click Config/homing/softlimits and OK, but no data entry into the table is necessary, to have them take affect. Since I have a lathe/mill combo and sometimes the lathe chuck or the tailstock is on and my movement is restricted so I needed a easy way to change limits.
