Hello Guest it is November 22, 2026, 02:03:57 PM
Author Topic: Laser not cutting on axis  (Read 13287 times)
« on: November 08, 2020, 04:02:53 AM »
Hi.
My laser has trouble cutting cleanly on the X axis. The Y axis is fine but need to make one or two extra passes for the laser to cut all the way through.
I am using a 7.5W (optical) diode laser with a fixed focus.
I have carefully aligned the laser head in the vertical and have tried some adjustments with focus but no improvement.
Is this caused by the laser dot maybe not being a perfect circle? The laser is Chinese and I can't be sure of the optics in it.
Hoping someone out there might have experienced this before and have a fix.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Laser not cutting on axis
« Reply #1 on: November 08, 2020, 10:22:56 AM »
Rotate the laser body 90 degrees and see if the error swaps axis, do not change the focus though so keep it at the same height.
« Reply #2 on: November 08, 2020, 02:48:01 PM »
Thanks. I will give that a try
« Reply #3 on: November 09, 2020, 12:11:41 AM »
Yes, the problem moved with the laser head so that means the laser dot must be distorted, a line instead of a circle.
Annoying but I guess there is no way to fix that.
Thanks for your help
Offline ZASto
  •  434 434
« Reply #4 on: November 09, 2020, 02:38:08 AM »
If you have a line then your laser is out of focus.
Move your laser up/down or move your material accordingly.
My personality is who I am.
« Reply #5 on: November 09, 2020, 04:32:48 AM »
Tried that. Got a small improvement with a shorter focus but not able to completely eliminate the problem. Given that the problem moved from one axis to another when I rotated the laser head indicates the problem is mostly with the laser head.
However I find keeping the lens clean helps a bit. It gets dirty quickly.
I have heard of compressed air being used on the cut but not sure how to set that up or if it will have any effect.
Does anybody have any ideas?
  •  2,785 2,785
« Reply #6 on: November 14, 2020, 12:02:57 PM »
There are lots of K40 laser videos on youtube about using air to keep the cut clean.
« Reply #7 on: November 14, 2020, 04:32:14 PM »
Thanks. Checked a couple of of them. Seems to work so I got myself a coolant tube that I'll mount on the laser.
Watch this space.
