Hello Guest it is October 20, 2026, 03:48:31 PM
Author Topic: Is it possible to run Mach3 through job boundaries  (Read 6512 times)
« on: October 27, 2020, 05:47:24 AM »
Hello
I was wondering, if Mach3 has the ability to run through the job boundaries without manually having to move it. Right now, what I do is load the g-code and then manually see if the material is inside the job boundaries. But my question is, is there a way to make Mach3 do it itself? I hope you get what I mean here, I really do not know the proper words for this function. It should work the same as some chinese lasers have the "Frame" button on them.
Have a good one everybody.
