Hello Guest it is October 20, 2026, 11:30:09 PM
Author Topic: Mach 3 Programming Question  (Read 12901 times)
« on: October 21, 2020, 03:03:07 PM »
I have 2 programs that are nearly identical to each other (mirror images). The designs were made in Cut2D and then the coding was transferred over to Mach 3.
Program 1 does what it's supposed to at the end. Air turns off, tooling stops and goes back to the home position.
Program 2 for some reason does not stop at all. Instead it goes back to the start point (not even the home position) and starts over. It's like it's stuck on repeat.
Any idea why this would be happening? Is it a bug in the code? A setting in Mach 3 that would make the program start over automatically? I'm sure you can tell by now that I'm new to this software so any help would be appreciated.
Thanks!
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Mach 3 Programming Question
« Reply #1 on: October 21, 2020, 03:36:43 PM »
Has the second program got a M99 or M47 at the end?
« Reply #2 on: October 22, 2020, 07:16:50 AM »
No. it has an M09 to turn off the air. Then some coordinates to go back to the start and home position. Then an M30.
  •  9,374 9,374
« Reply #3 on: October 23, 2020, 12:01:05 AM »
Could you attach your problem Gcode file.
« Reply #4 on: October 23, 2020, 07:26:58 AM »
Attached is the last bit of coding.
Line N247741 is when the air turns off but then after that it repeats the cycle.
  •  9,374 9,374
« Reply #5 on: October 23, 2020, 07:43:54 AM »
That's perhaps not that helpful.
If you attach the complete problem file then it can be run here to see if there is an issue with the Gcode itself. At least that would rule out one possibility.
« Reply #6 on: October 23, 2020, 10:11:01 AM »
Here you go
Offline ZASto
  •  434 434
« Reply #7 on: October 23, 2020, 11:46:13 AM »
It simulates normally.
Two passes over same geometry at 0.0625 and 0.125 depth.
Could not find any errors in your code.
My personality is who I am.
« Reply #8 on: October 23, 2020, 12:36:00 PM »
Bingo! I think this is the problem. I only need one pass at 0.125 depth. Thanks.
I'll update the coding and hopefully it solves my problem
