Hello Guest it is November 01, 2026, 08:09:14 AM
Author Topic: Mach3 stops with SS communication error  (Read 18691 times)
« on: October 19, 2020, 09:49:32 AM »
Hello All,
In our 3 axis machine we are facing a weird problem. We are using ibag spindle which we are operating separately and mounted on z stage. When we are running a g code on the mach3 then mach3 stop after 3-4 minutes with communication error in smoothstepper. We tried to pinpoint the issue and we found that if we mount the spindle on the stage then this error comes and if we run the program without mounting the spindle then there is no error. There may be some electromagnetic noise which is stopping the program.
One more weird point is that if we remove all the spindle wires and simply put the spindle on the stage then also there is same error. I do not know what is the issue as we have used this spindle on our other 3 axis machines those do not have USS there is no issue at all.
Please help us to solve this issue we are using mach3 software to run the code.
Rinku
