Hello Guest it is September 30, 2026, 11:20:34 AM
Author Topic: Noob G Code question  (Read 26749 times)
« on: October 12, 2020, 10:51:21 PM »
So I am brand new to CNC and after a 2.5 year battle over receiving a machine that was being built for me and then receiving an incomplete pile of pieces I have my machine together and moving. I have no experience with G Code but love to learn new things. Tonight I tested movement with code for the first time. I wrote a simple code to start in the middle of a square, move out, move around and back to the center just moving air. Here is the code
%        (1)
G01
F50
Y-2
X2       (5)
Y4
X-4
Y-4
X2
Y2       (10)
The machine ran blocks 3-8 exactly as it should but it moved block 9. 4 inches and block 10. 4 inches. So it didn't end up back at center but rather at the back right corner. I ran it many times with the same result. Running Mach 3 with motors calibrated and tuned. Do I have a setting wrong in Mach, or am I not understanding the code or what? I know this seems ridiculously simple to most, but a guys gotta start somewhere. Even at 64. :) Thanks for your help
Holding on to bitterness is like drinking poison and expecting the other person to die....
  •  9,374 9,374
Re: Noob G Code question
« Reply #1 on: October 13, 2020, 01:05:53 AM »
Your Gcode ran just fine here so it is not that which is causing the problem.
I know it sounds basic but perhaps check the mechanicals of your machine for tightness or binding of an axis or even slippage of a coupling, looseness of a grub screw, etc.
Offline TPS
  •  2,627 2,627
« Reply #2 on: October 13, 2020, 02:40:30 AM »
Hello,
your code will only work, if you are in incremental mode (G91), not if you are in absolute (G90)
  •  9,374 9,374
« Reply #3 on: October 13, 2020, 02:56:04 AM »
Excellent.  :D
TPS has solved the mystery.
« Reply #4 on: October 13, 2020, 09:07:28 AM »
Hello,
Thanks to you both, to prove that I am a noob :) where do I check and change that? I've seen it but don't remember where. Also is one better for common usage.
« Last Edit: October 13, 2020, 09:17:51 AM by jdm033056 »
Offline TPS
  •  2,627 2,627
« Reply #5 on: October 13, 2020, 02:01:13 PM »
hello jdm033056 ,
the best Thing is to add it to your code.
 for example:
Code: [Select]
%        (1)
G91 (it is allways good to put a Header line in G-Code not only G91 or G90 some other basic's would be good)
G01
F50
Y-2
X2       (5)
Y4
X-4
Y-4
X2
Y2       (10)
« Reply #6 on: October 13, 2020, 03:40:08 PM »
Thank you. TPS
