Hello Guest it is November 16, 2026, 03:48:31 AM
Author Topic: Tutorial for ring engraving  (Read 20160 times)
« on: September 28, 2020, 10:04:40 AM »
First I apologize if this topic is not for this forum, but I really don’t know where to start so at least I hope you can point me to the right place.
I recently got my first cnc and use it with ArtCam and Mach3. I did some simple engraving and cutting pieces in flat materials and everything went smoothly. Now, I decided to try engraving on the rings.
Where can I find a tutorial how to do simple engraving on rings, so I can solve the following problems:
- Every engraving I make in ArtCam in Mach3 is mirrored (turned horizontally)
- How can I most easily determine zero correctly on the x, y(a) and z axes?
Midhat
