Hello Guest it is November 22, 2026, 09:03:26 AM
Author Topic: Which MACH3 or MACH4 Can Cycle is suitable for these do-it-all bits?  (Read 8976 times)
Offline reuelt
  •  520 520
Assuming I can slow down the spindle speed and only doing thru-holes,
Which MACH3 or MACH4 G-CODE Can Cycle would be suitable for these do-it-all bits?
"the gift of God is eternal life through Jesus Christ our Lord"
Offline TPS
  •  2,627 2,627
Re: Which MACH3 or MACH4 Can Cycle is suitable for these do-it-all bits?
« Reply #1 on: September 24, 2020, 02:13:00 AM »
i think it depends on your Controller. i am using a CSMIO and there it is done with macro M84 in Mach3.
Offline TPS
  •  2,627 2,627
« Reply #2 on: September 24, 2020, 06:38:10 AM »
code could be soemething like this
Code: [Select]
G21 G40 G00 G99 G17
G0 Z10                                     (lift z-up)
G0 X10 Y10                               (go to drill position)
M3 S1000                                  (spindle on with higher speed for the drilling)
G1 Z-5 F100                              (drill the hole)
M3 S100                                    (Slow spindle down to tap speed)
G84 X10 Y10 Z-10 R10 L1 F50     (tap and debur)
all S an F Parameter Need to be calculated to your pitch.
and you will Need a spindle Feedback.
« Last Edit: September 24, 2020, 06:39:54 AM by TPS »
Offline reuelt
  •  520 520
« Reply #3 on: September 24, 2020, 03:29:45 PM »
Thank you TPS
