Hello Guest it is November 07, 2026, 04:28:16 AM
Author Topic: Mach4 build 4517, M6 Not working  (Read 7496 times)
« on: September 19, 2020, 09:20:58 PM »
After switching computers and installing the latest mach4  build 4517 using a ESSv260 I can no longer get my m6 command to work.  I wrote the script just like Daz instructed in his videos but my machine still skips over the manual tool change.  M01 is turned on.  anyone have a suggestion?
Offline reuelt
  •  520 520
Re: Mach4 build 4517, M6 Not working
« Reply #1 on: September 20, 2020, 12:45:28 AM »
Is your "tool change type" setting set correctly?
"the gift of God is eternal life through Jesus Christ our Lord"
« Reply #2 on: September 20, 2020, 07:06:49 PM »
Yes, I've actually try both setting both nothing changes.
Here's the tool change macro
function m6()
   local selectedTool = mc.mcToolGetSelected(inst)
   local currentTool = mc.mcToolGetCurrent(inst)
   if selectedTool == currentTool then
   return
   mc.mcCntlSetLastError(inst, "Current tool == Selected tool so there is nothing to do")
   else
   mc.mcCntlGcodeExecute(inst, "G90 G53 G0 Z0.0");--Move the Z axis all the way up
   local changetoo = mc.mcToolGetDesc (inst,selectedTool)
   wx.wxMessageBox ("Change to tool number "..selectedTool.." "..changetoo.." and press ok to continue")
   wx.wxMessageBox ('Toolchange finished')
   end
end
   m6()
Offline reuelt
  •  520 520
« Reply #3 on: September 20, 2020, 07:53:02 PM »
The should be another  "end" after the last if statement.
« Reply #4 on: September 20, 2020, 11:18:12 PM »
Okay figured it out, my LUA plugin was not enabled.
