Hello Guest it is October 21, 2026, 11:34:22 AM
Author Topic: XHC ethernet controller & PROMA 150 THC  (Read 9034 times)
« on: September 18, 2020, 02:21:07 PM »
Hello, i buy purchased XHC MK3-ET controller and im having a problem.
I cannot get it to run THC in Mach3 Plasma mode.
Im using PROMA THC 150.
Mach3 is reading inputs in diagnostic(ARC OK, UP, DOWN) but Z axis doesn't move or when it does, its going random and passing min max values.
I read that cnc controller for that function should have a THC support.
Is it possible to write some kind of script/macro to get it running...
Thx
Offline TPS
  •  2,627 2,627
Re: XHC ethernet controller & PROMA 150 THC
« Reply #1 on: September 19, 2020, 01:10:10 AM »
Short answer NO.
« Reply #2 on: September 19, 2020, 03:53:17 AM »
Short answer NO.
Will replacing THC 150 with SD be a good idea?
  •  9,374 9,374
« Reply #3 on: September 19, 2020, 05:26:26 AM »
I have a feeling that it is the XHC controller that you will need to replace  :'(
