Hello Guest it is November 07, 2026, 04:40:39 AM
Author Topic: "are you sure you want to exit?" message problem  (Read 6416 times)
« on: September 18, 2020, 11:17:22 AM »
I accidentally turned off the "are you sure you want to exit?" message, and I'm having a heck of a time figuring out how to turn it back on.  I'm assuming it is in one of the .ini files, but I can't find it. Anyone have any ideas what it is labeled as, or where to find it?
Thanks for any help!
David
Offline jbuehn
  •  101 101
Re: "are you sure you want to exit?" message problem
« Reply #1 on: September 18, 2020, 11:53:32 AM »
I think that one is in the Mach4GUI.ini in your roaming AppData folder.
« Reply #2 on: September 19, 2020, 09:38:23 AM »
Correct!
Thanks jbuehn!
In windows 10:
C:\Users\(your user name)\AppData\Mach4GUI.ini
DontConfirmExit=0
